Anyone have 215 tire to 17X8 wheel?
azureblaze
Car: NISSAN ALTIMA 2.5S CVT
A/C stock wheel comes 215/55/17 on 17X7.5 wheel.
I'm gonna replace my rim and new rim not come 17x7.5only comes 17x7 and 17x8What do you think guys 215 tire to 17x7 or 17x8 ?Which one is better?
marlin29311
Car: 2008 Infiniti G35x
215 width tires won't fit on a 8" wheel, they're too small. Your tire shop should be able to indicate that. Tires get wheel width ranges - the stock 215 bridgestones we have can fit anywhere from a 6" wheel to a 7.5" wheel, with the maunfacturer standard size of 7".
The 215 would fit perfectly on a 7".
Consider getting new tires - the stock turanzas are garbage. If you get the 8" wheel, you can push up to 245 width or possibly higher.
azureblaze
I figure out to tire conversion. it say 235/50/17 is exactly same as 215/55/17 diameter 26.3
Do you think it can fit to 17x8 wheel?Don't you think wider tire get more gas ?
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
dont you think wider tire get more gas?
are you asking if a wider tire gets better gas mileage? if so, no wider tires do not get better gas mileage, actually its slightly worse, more rolling resistance and rotational weight.
marlin29311
azureblaze wrote:I figure out to tire conversion. it say 235/50/17 is exactly same as 215/55/17 diameter 26.3
Im not sure where the 235 width question came from...but yes, the 235 will fit perfectly on your 8" wheel - it will even fit perfectly on your OE 7.5" wheel.
And scandanavian is right, you technically get lower gas mileage, but better grip of the road...
azureblaze
So 235 tire is better than 215?If I use 235/50/17 tire to 17x8 wheel, What offset would you recommand?I only have +40 and +47 wheel
Thanks!
marlin29311
If you want more grip on the road, a 235 is better than 215...
You can use the stock 7.5" wheel with 235's...
If you are getting a new wheel, you could get away with +40 on a 8" rim....look around though, there are a lot of people that discuss what offsets to get..
azureblaze
You mean 17x8 with +40 offset is ok?We're talking about 17x8 rim, not 18x8 rim, right?thanks
marlin29311
17" or 18" doesn't make a difference - you would just change your sidewall ratio for that. It's the 8" width that affects your offset - you should be fine.
azureblaze
Thanks! lol
azureblaze
What about 215 tire on 17x7 rim ?original 17" stock rim is +45 offset but one I look for has only +40 and +47Do you think one of these work?
