JDMEnthused wrote:ill be running an 8 inch wide tire on the rear. ill be running some 50mm rear quarter panels though.
Hahahahahah Are you serious? an 8in wide rim would need like -70 offset to need +50s.
clutch Kick drifter wrote:I was either gonna get them rolled or get flares. Id go 10in in the rear and like 8 in the front and still deciding on the offset. WHat would be the best looking offset for the rear?
You shouldnt need flares. However, 2in of stagger is kinda wack, I'd either man up and get the 17x9 +15s for the front or do 17x8 +25 in the front and 17x9 +15 in the rear.
17x9 +15 on the front is doable on rolled pulled stock fenders with a 235/40 tire... if you wanted to use a 255/40 you would need over fenders though.
