menlund19 wrote:
Thanks Dave...couple more questions...have you ever had the Goodyear RSAs? Are the A/S Plus better than the RSA in wet and snow? Worse?
The reason I ask is because I think the RSAs are rated poorly in snow, but I have had no trouble this winter with these tires. Of course the AWD helps.
I picked up my M in late February and I thought the RSAs were fine in the snow for the first few thousand miles. You'll find that they wear out most of the tread after several thousand miles and then you hit hard rubber that isn't good on anything. Lots of rants on this forum over the RSA's but I didn't notice any problem until they had 10 to 12K on them.
I should mention that when I bought the Pilot A/S I had an old car that I used for snow. I'd use the old car for snow/ice days and the Pilot A/S if the roads were clear. The Pilot A/S are a good pick for that situation as they handle fine on dry roads, even below zero temps.
I live down the road from you in Rochester MN. For our weather I'd suggest the PS2 and a winter package. Go with the Pilot A/S only if you have another ride for the bad snow days.
