P.W.Royce »
https://forums.nicoclub.com/p-w-royce-u20160.html
Mon Oct 11, 2004 3:58 pm
I have a '91 HB with maybe 130K miles on it. I say maybe because the odometer has not worked for the last 2 years, and was malfunctioning for who knows how long before I bought the car. I have replaced/adjusted the valave shims and the head seems to be in great shape (very clean). I also replaced the crank to conecting rod bearings as one of them had cracked in two and was making some noise (the other three had not cracked yet). Again the bottom end seemed very clean. I reassembled the engine and everything ran great, no leaks, no oil burnt or used in any way. All of the sudden last month I start seeing drips on the ground. First one from the oil pan, then later from the bell housing lip and the transmission drain plug. Now I have oil drops forming from a half dozen places on the underside of the engine. The oil pan to engine block seal looks good, which brings me back to my question: Has anyone had their front or rear oil seals go out ?
