anyone had any issues using a FWD water pump?
f s t caz
Car: VG30ET D21 Extended Cab Pickup
I started my motor, finally, and the engine ran fine, other than a clacking sound coming from the front of the motor. after fearing for the worst, i removed the front timing covers and checked the cam timing, and i'm good on that account. I then put the top cover back on, as well as the CAS and the crank pulley(no belts) and started it . The result was no noise. Thinking i was ok, i put he lower timing cover back on and started it. Still no noise. Hook up the alt/waterpump belt, start it, its making noise.
I put a brand new Nissan Pulsar DE waterpump on back in feb and finally got around to installing the motor the other day. When turning the shaft by hand, there's no reisistance at any point, so i can't imagine there being anything lodged behind it. And no, i'm not using a fan w/ clutch on the end of the water pump.
Anyone have any tips or thoughts before i remove the water pump for inspection?
thanksChris
and just b/c
minutericesentra
Car: 96 Z32, 06 R51
One of the pulleys rubbing against the timing belt cover maybe?
float_6969
Mine does the same thing when I start it up, but then it goes away once I gets warmed up. I can't figure it out. I'm going to replace it with an ET one when I pull the motor next week to replace the rings and see how that goes.
f s t caz
float_6969 wrote:Mine does the same thing when I start it up, but then it goes away once I gets warmed up. I can't figure it out. I'm going to replace it with an ET one when I pull the motor next week to replace the rings and see how that goes.
i just let it run for a little while longer and it did go away, but then it came back after a few minutes :confused:
BoroBoroS13
Car: S13, RS13, and S14
I toasted my pump the other day but it was my fault. Blew up an old radiator hose and the pump ran with low coolent for under 5mins and was toast. Thats kind of weak considering my friends old KA pump lasted over 10mins with low coolent until he cought the problem.
As for making noise, I had no problems till I killed the pump and it made a **** load of noise.
NeedCAforS13
Car: CA swapped S13 coupe
mine works fine... I never hear any noises coming from my water pump:) but the clearance between the pulley and the timing cover is really close, so maybe they're hitting together? I dunno
Sean
float_6969
Sean, DE or ET pump?
NeedCAforS13
DE. gotta get that pulley, just haven't found time recently... Dee still have that extra one in your closet?
Sean
minutericesentra
Car: 96 Z32, 06 R51
If Dee doesn't have one I've got one I'm trying to get rid of fo' cheap!
nextlevel
if NeedCAforS13 doesnt take the pulley I will e-mail me at [email protected]
NeedCAforS13
I'll just wait till Dee comes back into town:) its all yours nextlevel!
Sean
minutericesentra
Car: 96 Z32, 06 R51
Email'ed you nextlevel.
nextlevel
alright e-mailed you back I can make paypal payment as soon as you get shipping price.Thanks
boost_boy
Quote »Dee still have that extra one in your closet?[/quote] Yeah Sean, it still here. That (IMHO) is just too cheap of a part to try and make a buck off of. It's yours as well as I have no use for it...............
Dee
NeedCAforS13
got any plans to come into Orlando? if not I'll send you $5 or something to cover shipping:)
Sean
boost_boy
I'll pack it up and send it. You can paypal me later, if you want. Just email me your address and I'll get it out to you.
Dee
