Hi guys, anyone got any webspace to upload the files to and share them for all, or should I email them to you individually?
Sorry, been pretty busy lately, forgot about this thread! All my design work and stuff is on my old computer and I need to chuck the hard drives into the new one after I install the new windows on it, so it may be a few days before I send the files off... but all good!
Someone try sort some webspace, perhaps Wes would be happy to host it up?
I'm happy to share this work around with you guys as long as you guys give it back to the community if you develop it further... as I spent a bit of money on the CMM measuring to get absolute measurements of the parts in the valvetrain.
The assembly basically consists of a fully positioned valvetrain assembly (of only one cylinder, as that's all that's necessary for simulation), ready to be spun. I've set up the intake cam to spin as the crank spins, and opening and closing of the intake valve. I've only positioned the exhaust cam there and haven't set its relationships up yet, so a small amount of rigging to finish that aspect off before you can get designing with the exhaust lobes.
Also, you may need to check the configurations tab as I think I've made a configuration to suit my stroker motor which has had some machining slightly reducing deck height and head thickness... and revert these measurements back to stock (available in the FSM if I haven't already done it through configurations).
Most things should be labeled nicely. If anyone finds mistakes in my work or better ways to do things, pipe up as I'm always keen to improve my solidworks skills
