Anyone got an aux air controller, idle somethin er other, whatever it's called?
Mycarispurty
Car: 1977 Datsun 280Z, 1997 Honda Accord EX
I need that thing that bolts on the top of the intake manifold and helps control air at idle or whatever. It's kinda barrel shaped and has a plug at the end. The one on the car I'm getting has a busted plug and the p/o just kinda had the wires hanging in the sockets of the plug on the wiring harness side. I'd like to replace it with one that's known to work and still has the plug.
boost_boy
Mycarispurty wrote:I need that thing that bolts on the top of the intake manifold and helps control air at idle or whatever. It's kinda barrel shaped and has a plug at the end. The one on the car I'm getting has a busted plug and the p/o just kinda had the wires hanging in the sockets of the plug on the wiring harness side. I'd like to replace it with one that's known to work and still has the plug.
If it's the one at the tip top that takes like a 19mm wrench to remove, most are cracked, but just because they're cracked, doesn't mean they don't function. It's the idle-up valve when the A/C compressor is engaged. If you don't have A/C, then don't worry about it. All mine are cracked, but they all work............
Dee
Mycarispurty
Oh, well thanks for the reply Dee. I don't think this car has a/c (dont have it in my driveway yet) but I might just replace it with one anyway that at least has most of a clip still on it.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
theres one on my engine, but i dont know if it works or not. you are welcome to it if you want.
driftin8ez
Car: 92 Coupe, Turbo Miata
get on from your old KA. Goes right in and works fine.
