AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.html
Sat Jun 20, 2009 1:13 pm
Compressor - big thing on side of motor that rotates off a belt driven by your motor
Bracket - bolts to block and holds compressor
Tension/Idler - Basically a pulley that's on the bracket and is attached to the compressor via a belt
Lines - lines that go from compressor --> condensor --> dryer --> blower --> vents
Condensor - looks like a radiator, pretty much is.
Dryer - cylinder shaped thing next to the battery (read below)
VERY IMPORTANT:
Unless it's completely sealed off, you're going to need a dryer. If it's exposed to air for a period of time, it's contaminated. You're either going to have to get a new one or get one that is still sealed.
