Rosco »
https://forums.nicoclub.com/rosco-u15015.html
Tue Dec 18, 2007 4:43 pm
Start when the car is cold. (after an overnight rest)
Turn key on, go to decel air settings.
Set throttle to 1%.
Set NE1 to about 4.
Set NE2 to about 5.
Start car.
Adjust NE1 until you get a smooth idle while the engine is still cold. Now start turning it down as low as possible while still maintaining a good idle.
If the car starts sputtering and getting rough, you just went too low. Turn it back up very slowly until it smooths out. You want to leave NE1 on the lowest possible point with a good idle.
Now set NE2 to be about 1 higher than NE1.
This formula shoudl eliminate any stalling or popping from the BOV being open.
Theory: Throttle setting tells the SAFC whenever the pedal is depressed less than 1%, the SAFC should control fuel and ignore everything else (including the MAF)
NE1 is the first RPM point you have selected in your NE Point settings. I put mine at 1000 rpm. I set NE2 at 3000, then NE3 at 4000, and so on in 1000 increments. Setting NE1 down at 1000 gives you the ability to control fuel at idle really well. Besides, you probably don't need to adjust anything between 1000 and 3000. (turbo spools after that, right?)
Setting the air flow percentage at NE1 is basically telling the SAFC a number to use whenever it reaches that RPM and less than the throttle setting. So, as the throttle is let off, the SAFC looks at the NE1 and NE2 points. As RPM rolls back, there is going to be a reduction in air into the engine, yet the MAF has already seen it. The stock ECU is attempting to send the fuel for that air that is now missing... hence your stalling and backfiring. The SAFC catches that signal, ignores it, then tells the ECU exactly how much air flow you have according to your DEC AIR settings at those RPM points. Get it?
RPM comes down, hits NE2, SAFC sees 10%. It tells the ECU it needs 5%. (because you picked that number.) Now the RPM won't dive so hard like it was. It reaches NE1, SAFC sees 6%, you told it 4% and it tells the computer only 4%. The idle sets steadily down to where its supposed to and everybody is happy.
The SAFC is all about tricking the ECU into doing what you want it to.
***I am not the author of this "guide"***
I like white chocalate chip macadamia cookies......
