42alms24sebring wrote: square root of the meaning of life.
Did you leave out a 2 in the exponent? The particular part of the solution you posted doesn't make sense otherwise.Looneybomber wrote:We're doing 2nd order nonhomogeneous equations. Because of break, I don't have class again till Thursday.
The problem:
y''-2y'-3y=3te^t, y(0)=1, y'(0)=0
What you actually have is a first degree polynomial times exp(2t). So you need a coefficient for each of the terms. Consider if the function on the right side was (t^3 - 2t^2 + 4t - 2) exp(2t). Then the particular solution would take the form Yp = (At^3 + Bt^2 + Ct + D) exp(2t). In your case, think of it as looking at this: (3t + 0) exp(2t). Inserting the t in the case of resonance is necessary because the coefficient A is not solvable (A = 0). I can see the confusion though , but its just an entirely different rule.Looneybomber wrote:So, back to my problem, naturally I picked Y(t)=Ate^(2t), replacing the coefficent with A, however, the correct function to use was Y(t)=Ate^(2t)+Be^(2t). Why did they pick the function that they did? I know if you have a resonant response, you add an extra t, for example, y(t)=e^-t would result in a function of Y(t)=Ate^-t, but is this resonant?
Good eye, I did leave out a 2! I'll go fix that.C-Kwik wrote:Did you leave out a 2 in the exponent? The particular part of the solution you posted doesn't make sense otherwise.Looneybomber wrote:We're doing 2nd order nonhomogeneous equations. Because of break, I don't have class again till Thursday.
The problem:
And there's my problem, I ignored that I had a polynomial and focused solely on the exp.C-Kwik wrote:What you actually have is a first degree polynomial times exp(2t). So you need a coefficient for each of the terms. Consider if the function on the right side was (t^3 - 2t^2 + 4t - 2) exp(2t). Then the particular solution would take the form Yp = (At^3 + Bt^2 + Ct + D) exp(2t). In your case, think of it as looking at this: (3t + 0) exp(2t). Inserting the t in the case of resonance is necessary because the coefficient A is not solvable (A = 0). I can see the confusion though , but its just an entirely different rule.
I try to look the part, without actually playing the part. That's why I get on here and wolfram alpha for help. But thanks man!float_6969 wrote:Dustin, you haz lots of smarts.
No problem. Though, its self serving actually. Helping others with this helps reinforce my math skills. I hadn't touched this stuff in a while (we usually use Laplace transforms) so its great review.Looneybomber wrote:And there's my problem, I ignored that I had a polynomial and focused solely on the exp.
I think you've helped me with digital logic (boolean algebra) and now diff eq. Thanks.
That's what everyone else in my major says; Laplace is when diff eq starts getting useful. Our diff eq teacher mentions the same thing. 4th order ODE's is when he says diff eq gets useful, but that's because he's a physics PhD and talks about beam deflection in bridges and other things. But you gotta start somewhere right?C-Kwik wrote:No problem. Though, its self serving actually. Helping others with this helps reinforce my math skills. I hadn't touched this stuff in a while (we usually use Laplace transforms) so its great review.Looneybomber wrote:And there's my problem, I ignored that I had a polynomial and focused solely on the exp.
Yea, I'm really wanting to get over there and hang out, but I'm super busy with work right now. Work should slow down by the end of the month and I should have a lot more free time.Looneybomber wrote:I try to look the part, without actually playing the part. That's why I get on here and wolfram alpha for help. But thanks man!float_6969 wrote:Dustin, you haz lots of smarts.
What I do have is a lot of beer! Just bottled 10 gallons on Sunday (gotta be around 30gal bottled now). Sadly though, I haven't had time to BREW another batch, IE, your chocolate stout.
Curious. Is that true for controls engineers too? I'm starting my second controls class and it sounds like diff equations using Laplace is useful for understanding and predicting system behavior.PapaSmurf2k3 wrote:I recall hating Diff EQs when I took it, and I really have no desire to re-visit that. Beam deflection was easy as hell, provided you have the formulas you need. Laplace and fourier transfers are rarely used as well.
Calc is pretty useless unless you HAVE to derive your own formula for some reason. There are very few physics formulas that are used in real world situations that require calc (one of the only ones I can think of is the car-accident scenario, where a car is stopped in the road, oncoming dude starts braking and stopped car starts accelerating... where do they crash [if they crash]).
Glad I'm not the only one who thought this.themadscientist wrote:4.11:1 is great for drag racing, but sucks on the highway.
I did a brute force method of putting together a PID control for a balanced inverted pendulum a couple of years ago. It wasn't hard to do but was tedious without a good starting point. I have to wonder if I could do it faster by modelling it. Does your experience in this also include high precision controls (medical equipment, high precision mills, etc.)? There are lots of medical equipment companies in my area so it may be important for me to consider what they are looking for in this aspect.PapaSmurf2k3 wrote:Yes. You will very rarely encounter a system that you have to use Diff EQs to predict. Most times you can just rely on your engineering background to say "we need more of this", or "this" based on some sort of experimental outcome. I'd venture to say every company worth a s*** makes you validate whatever math you'd be doing by building a physical prototype or 50.
Yeah, you have to be in an extremely specialized field/application to even graze the surface with that stuff. I suppose if you're the guy making the CNC mill, you might use it? Then again I can't even really think why, you'd just use a stepper motor or encoder or something to tell distance/position. Everything after that is just G-code, which doesn't use Diff EQs at all. Not to mention most programs are already based on some sort of software that already exists by this point. You really have to be on the "inventing" side of very specialized things to use it.C-Kwik wrote: I did a brute force method of putting together a PID control for a balanced inverted pendulum a couple of years ago. It wasn't hard to do but was tedious without a good starting point. I have to wonder if I could do it faster by modelling it. Does your experience in this also include high precision controls (medical equipment, high precision mills, etc.)? There are lots of medical equipment companies in my area so it may be important for me to consider what they are looking for in this aspect.
Mech-E student.Looneybomber wrote:It's off topic, but I've looked into PID's, for controlling a heating element for a larger automated home brew setup.
Are you a mech-E student/graduate?
Gotcha. My most practical exposure to it was through the grad student I was working for in an internship this summer. Though, we ended up not getting really deep into it anyways as other priorities took over and they pulled me into the priority project. I was kinda hoping to get more exposure to it. My thoughts would be they would likely seek Masters degree holders for that kind of work, but it could never hurt to know a little more about it.PapaSmurf2k3 wrote:Yeah, you have to be in an extremely specialized field/application to even graze the surface with that stuff. I suppose if you're the guy making the CNC mill, you might use it? Then again I can't even really think why, you'd just use a stepper motor or encoder or something to tell distance/position. Everything after that is just G-code, which doesn't use Diff EQs at all. Not to mention most programs are already based on some sort of software that already exists by this point. You really have to be on the "inventing" side of very specialized things to use it.
