What's an ECU re-flash?NismoB13 wrote:Don't forget the lighter flywheel, pulleys, ECU reflash, and better clutch.
I read a while back that this engine is not designed to produce high revs. The main reason for that is the bore/stroke ratio. This engine has a fairly long stroke, which results in fairly long piston travel. What that means is that at higher RPM's the pistons are traveling faster than most 4 bangers. What I read was that in this engine, at 6,500 RPM, the piston speed is equivalent to most engines running at 8,000. It's something to consider when trying to get those high revs.zspeed10 wrote:So your saying 200 or so is all I could expect without blueprint and the sort? What about some head work? Valves and springs, get 'er up to 7500 rpm? Thanks for all the input guys. I would intend to keep daily drivable so I'm glad to hear about those cam grinds you're familiar with.
