Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Tue Aug 26, 2008 12:54 pm
There are quite a few aspects that you have to consider when getting a good paint job.
1st is the quality of the paint. Obviously you want something that is going to be durable. Contrary to popular belief, paint is really expensive. A friend of mine had his Z painted chameleon and spent 4 or 5 grand on paint alone. Obviously, athens blue won't cost that much.
2nd is how the shop plans on repainting the car. Some will do a light sand, mask off certain areas and paint over the existing paint.
Others will sand down to the primer, remove your doors, hood, trunk...etc, fill in any dents, then paint, paint, paint, paint, sand, clear, colorsand, clear, colorsand, clear, colorsand.
At anywhere between $50-150/hr, all of that painting and sanding gets expensive.
The one area that seems to always have orange peel is the lower part of the doors. Be sure to check that for texture. If it's smooth and glossy, the shop probably did a good job on the rest of the car.
