emperor_lunchbox wrote:is 12:1 too rich for 8 PSI?
Stock fuel PSI is in the 42 to 45 PSI range. A 12:1 FMU is going to add an additional 12 PSI for every 1 PSI of boost. So at 8PSI boost, tack 96 PSI on top of 42 to 45 PSI. It isn't recommended to go over 100 PSI wrt the fuel system. You can run an FMU at 12 PSI (I have) but I wouldn't recommend it for an extended period of usage. You could run a 12:1 temporarily until you can pick up a recalibration kit/disc. Your best bet is to go with a 6:1 or 8:1 FMU disc...that will keep you under (or right at) 100 PSI.
emperor_lunchbox wrote:so which would be a better solution for 300-350 HP?
The SAFC is the better of the two, when considered against an FMU. However, both of these options are poor when considering a 300 to 350 HP goal...for this kind of power output range, you need precise fuel delivery across all RPMs and load ranges along with proper ignition control, and you're only going to get that with a standalone or tuned ECU.
