Victor »
https://forums.nicoclub.com/victor-u94029.html
Fri Nov 11, 2011 2:22 pm
They are supposed to have a one way valve built in that lets one man bleed the brakes by himself. I read mixed reviews on them. Some people swear by them and think they are great. Other people say they leak after a while or break off, ruining the caliper unless you can drill them out. One person said one of his let go while driving, causing him to loose his brakes. Some people reported them rusting and getting frozen. They cost around $7.99 to $9.99 for two. Stainless steel speed bleeders are even more expensive, maybe $15 each.
Update, I found another problem reported with speed bleeders. They put some dry sealant on the threads to keep air from being sucked in around the treads when the bleeder screw is cracked open. This sealant is only good for about four times opening and closing, then air will leak in unless it is replaced with some new sealant that costs $10 for a tiny bottle. You have to remove the speed bleed screw, clean it, apply the sealant, and then bake it in your oven to dry it.
In the meantime fluid is leaking out of the open bleeder screw hole unless you saved you old screw to temporarily plug it. Also, the sealant will harden up in the bottle so you will probably have to keep buying it.
Victor on Mon Nov 14, 2011 10:11 am, edited 2 times in total.
