Anyone ever see a service body on a 720?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
fastboatman29212
Car: left this forum. Sold my truck.
Anyone ever see a service body on a 720? It even had dual rear wheels! It was parked next to this 1974 Datson 620 at my local salvage yard. I wonder if these little trucks really came with service bodies from the factory or if it was added later. These trucks just don't have a lot of extra power for that kinda weight!
Thought you might enjoy the photos. :chuckle:
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
My factory service manual notates that they did sell cab-only no-bed models so that coachbuilders could make things like this, just like the big boys!
fastboatman29212
But did they come with a dually rear?
captainzeros
Car:
1973 Datsun 240Z
There WAS a factory one ton 720 with a dually rear end.
fastboatman29212
I might pull the transmission out of that service truck.
Aven
Car: 84 720 Kingcab
My dad had a flat bed 1ton with duallies. It came without a bed. It was a work horse. They ran it for several years hauling metal and whatnot for his machine shop. Never once heard him complain about it.
fastboatman29212
Did it have a heavy duty transmission? I want to pull the transmission from this truck and use it on mine. If the transmission is the same as all the other 5speed MT then I may not be in any big hurry.
captainzeros
Car:
1973 Datsun 240Z
I'm pretty sure the only differences were that the heavy duty truck had beefier leafsprings and the same low differential gearing that the 4wd trucks had instead of the higher gearing that the 2wd trucks had.
Those were common.
I drove one with an A-frame utility bed when I worked a summer job at a glass / window factory.
fastboatman29212
captainzeros wrote:I'm pretty sure the only differences were that the heavy duty truck had beefier leafsprings and the same low differential gearing that the 4wd trucks had instead of the higher gearing that the 2wd trucks had.
So, let me ask a stupid question, since I would rather sound dumb than misunderstand something and mess things up.
It sounds like the trannys on these trucks are all the same, BUT the rear end DIFFERENTIAL differs based on the model, 2WD, 4WD, 1 ton etc. Right? So if I get the transmission out of the truck at the salvage yard, it should be exactly the same. Right?
Right now, my 5th gear is missing a tooth, so I only run 4 gears. Even without 5th gear, I get 22mpg no matter how I drive. I have oversized tires, and so I get 10% more speed from each gear than if I was running the stock 14 inch. The oversized tires haven't improved my gas mileage though.
captainzeros
Car:
1973 Datsun 240Z
According to my books, yes, that is correct.
86 720
Car: 1986 720 4cyl Standard Cab
I have seen a few flat bed duallys.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
If its original 720 it would work, that is its the same. I run a dogleg box from a cifero in mine. a direct bolt on but the gearbox leans a little with the Z engine.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
None shipped from the factory with bodies on them, cabs only. I owned one for a year. It got unbelievable fuel mileage and was a polar bear in the snow.
Return to “Datsun 720”
