Anyone ever run a DOHC motor on the SOHC wiring harness/ECU?
mechman900
Car: 90 240sx
Wow my 1st post on NICO...
I recently blew up my SOHC motor, picking up a DOHC motor to replace it. I'm not sure what exactly come with the DOHC motor as far as wiring harness etc. I was wondering if anyone has sucessfully used or modified the SOHC wiring harness to run the DOHC engine? I'd really rather solder some wires, etc than go chasing down a wiring harness and whatever other parts people normally use for the swap. (maf, ecu, etc)Thanks for any helpful info!
onosqv
Car: '92 240sx Vert
Go chase down a wiring harness, you'll thank yourself later... .
If you REALLY want to find out, download the FSM for the 89-90 240sx & 91-94 240sx - there are wiring schematics on there. You can find the FSM via google or on these forums somewhere.
