thank you kind sir for the info, so i take it i will have to drill 4 new holes, can i use any of the existing holes?crzycav86 wrote:I've done it.
If you use a drill press, it's gonna be easy as pie.
Bolt one of the holes together, and match up the hub bore. Then the other 3 holes will be aligned.. so you can just drill. If you don't want to go through several bits, just spray some type of lube/oil to absorb the heat.. and make sure it's a good quality drill bit.
