anyone ever had a p0500 code in 00 q45?
JOHNQ
Car: 99Qt
02 Q
03 M
had the 2000ae scanned for ses light and got back p0500 mil (vehicle speed sensor "A").also had a p0330 pending ks code but that didnt trip the ses light.no problems with the gauge cluster.car seems fine, just put on a new master cylinder, fuel filter and freon recharge 1 week agoany ideas as to origin of p0500 code would be appreciated
96'er
Car: 1996 Q45
John:
If you haven't already downloaded the FSM, here it is, http://www.nicoclub.com/FSM/Q4...0_Q45/.
Review the section on codes and follow the manual to isolate the problem.
Good luck.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
JOHNQ wrote:car seems fine, just put ....... freon recharge 1 week ago
I have to wonder what that will do to cure the problem as to why it was low? Did you also add the appropriate amount of lubricant? Evacuate and replace drier?
Modified by maxnix at 8:21 PM 4/26/2009
JOHNQ
Car: 99Qt
02 Q
03 M
along with the dye asswipe!dont answer my posts unless you can answer my original question
qship96
Car: 1996 Infiniti Q45
Was that response really called for? Tough to be a beggar and chooser all in one, and expect to recieve much help around here.
Brians comment actually was helpful, if you understand a/c systems and want a correct diagnosis and repair- many shortcuts taken in the a/c business,as it is very profitable for many shops to make a quick buck with a set of gauges and a cylinder of refrigerant.....$50 for 5 minutes and send em on their way- see the signs popping up at every corner gas station this week as the weather gets hot- everyone looking for the cheap quick fix.
JOHNQ
Car: 99Qt
02 Q
03 M
thanks i didnt know i was beggin, im not worried too much about my a/c, otherwise i wouldve put that in the title. the whole a/c procedure took about 45min. plus added the dye at the end. again i was asking what would cause the p0500 code. i merely wanted to state what the last most recent things done with the car as i got the code a week after this work was done. maybe if i go spend some money on a new compressor,evap, piping, and condensor i might fix my p0500 code. i dont want to sound like im going the cheap route.
qship96
96’er wrote:John:
Good luck.
Follow the diagnostic procedures in the factory service manual handed to you in the above link, or take it to the Infiniti dealer for a check-up. Knock sensor code will require quite a bit of labor to properly get to the sensors, and about 300 in parts alone to fix.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Obviously not interested in repairing malfunctions, only superficially treating symptoms.
Good luck!
