anyone else out there eliminate power steering? what size belt do i need?
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
What size belt is needed to connect the water pump directly to the main pulley? Everything else is gone save for my p/s pump which does no good other than act as a tensioner for my water pump belt.....
Any info?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
It would help to know what kind of car you have. We might be able to help you then :)
E Dogg
Car: 1997 M3 sedan
91 fastback with 95 KA24DE sorry
C-Kwik
I'm not sure anyone would have this info readily available. You may have to take some measurements and then try to find the best fit at the autoparts store.
eddiec
Car: 91 S13
wrap string around intended path, hold snug but not tight. take off string and measure. take measurement to parts store and get closest fit. actually get 3-4 around that size so you can have several on hand to try out.
trpower7
Holy crap, basic common sense and logic solved a problem. Talk about things I don't often see on NICO............
NISTECH
when you say everything else is gone....is your alternator still there? how are you going to install/adjust this belt? water pump doesnt move nor does the crank pulley.
E Dogg
Car: 1997 M3 sedan
i have my alternator but the belt for the p/s pump is the one that moves the water pump. I was hoping somone else did the same thing and knew what size to get. ill measure it thanks guys
eddiec
Car: 91 S13
youll have to remove the crank pulley to slide it all on since you will have no way of adjusting tension.
E Dogg
Car: 1997 M3 sedan
thats cool better than hearing the power steering pump push air through itself
if i had acess to cnc stuff id just make a tensioner and bracket...mabye extras to sell too
