Anyone else have issues removing the stock SR intake manifold?
kanecain
Car: 1993 Nissan 240SX Fastback, 2001 Toyota MR2 Spyder
I've removed all screws, but it seems like it's getting stuck in the upper right-hand corner towards the front of the car. It just won't lift off the engine. Please help!
It's getting stuck right about here:
nzmoman
Car: 240sx 2 of em' and always lookin for more
you just have to work it off...
you also need to make sure the seal is broken loose between the upper and lower mani.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
I can't see your pics, but when I replaced my intake gasket I had to remove the whole intake, not just the plenum. Hope that helps you out
nzmoman
at second glance I just realized this was the s13. I was thinking s14...
kanecain
nzmoman wrote:you just have to work it off...
Yeah, it took a while, but I finally got it off. I had to remove both parts of the mani. Thanks for the advice dudes.
otterman
Are you taking off the runners and the bottom part of the manifold?
It's a pain in the *** if you don't.
Make sure you put it on as one unit too or you could have a boost leak there.
*edit: Oh I guess you already got it off. Well make sure you put it on as one piece like I said, save you some head ache*
