ChiQ45 »
https://forums.nicoclub.com/chiq45-u10678.html
Thu Feb 19, 2004 1:45 pm
Hi,I have a 1993 Q45 169000 miles, dunno if anyone remembers me...got it off ebay. I been gone fer awhile. Anywho...when i hit the gas pedal the car seems to shake a little, also when i give it gas and the lights in the car seem to go dim intermittingly (like dim bright dim bright dim bright). Since i got the car i still have not checked the timing chain guides (i have a feeling they're not metal) changed the spark plugs to OEM, I've been having to add a quart of oil every month and earlier depending on how much i drive it (i think because of valve cover leak), the smoking has died considerably since i flushed the engine, but it still kicks out a cloud of white smoke when i give it gas from a stop in traffic...and the oil cap seems to get white foamy gunk on it sometimes. Also i changed the air filter but theres a film of oil all over the intake and air filter now. are these symptoms of a dying chain guide or is it all caused by the leaky valve cover? or anything anyone can suggest? (junk it?)
Thanks in advance, Chi
P.S.the cottman's transmission is running strong! had a huge transmission cooler put in parrallel with the radiator looks like i have 2 radiators now...no leaks from the transmission runs great shifts smooth...but the transmission kicks going into reverse...they said it was normal for a big car?
ooops sorry maybe this should be moved to the mechanics
p.p.s.
the new fuel pump works great still...i'd hate to junk it since the new (used) transmission, plugs, pump, filters, flush the car runs great except for the problems above....also crappy gas mileage OMG like 9 miles per gallon sucks
