mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Fri Aug 11, 2006 1:26 pm
Yeah I know. I have done just about everything I know so far except to check for plugged cats. I used the Consult II on it a couple of days ago and watched the o2 sensors on both banks to see if one side was running richer then the other because I figured that maybe when the previous shop did the guides that they may have got one side off time a notch but both o2 sensors are giving equal readings at all times so seems good there too. Only other thing I can think of is the cats. go to my profile and see what I posted on what I have done so far if you want so you can get an idea of where I stand now. I would like to get one of those home made consults that all I need is the cable and software so that I can perform the same as above when I'm not at work. I just don't want to end up ordering the wrong stuff.
Jeff Williams,I noticed that you have different power readings at 3 different times. Do you also have a switchable ECU? I noted that you get less power in the second run then in the 1st. I also had pulled 3 runs and in the same order the second run was less then the 1st and that was with it in level 2 mode. Level 3 brought it up about 5 HP from the first run while level 2 brought it down by about 5HP from the stock run.
Modified by mattd1979 at 7:46 PM 8/11/2006
