anybody used a GREDDY PROFEC e-01 e01 ELECTRONIC BOOST CONTROLLER
jeu510
Car: 73 datsun 510, 90 300zx na, 06 m35
i need to know if this boost controller is reliable, accurate, consistant, and easy to use....anybody used one of these before?
kingtal0n
Car: 240sx
it works but its a pain in the a** like most boost controllers.
my favorite BC for newbs is the greddy Type-S. Its got 3 dials very simple.
The best IMO is the profec-B. for the options it has, specifically, start boost function, overboost duty protection, and a built in peak boost memorize...
its very SIMPLE for what it DOES, comparible to ANY boost controller on the market, and easy to use if you UNDERSTAND IT, and install it CORRECTLY. The vacuum source is the most important thing. if the vacuum source sucks, so will the boost controllers functions.
jeu510
i know its gonna work, but is it accurate and consistant. a buddy of mine had the greddy profec b-spec 2 and it spiked on him. the boost was also not consistant. it would boost 12psi in 1st gear and 2nd gear, but in 3rd gear, it spiked to 15psi causing it to bog...he had it set 12psi.....i dont know if it was just his bc or if its the greddy profec b-spec 2 itself...
kingtal0n
Car: 240sx
operator
jeu510 wrote:i know its gonna work, but is it accurate and consistant. a buddy of mine had the greddy profec b-spec 2 and it spiked on him. the boost was also not consistant. it would boost 12psi in 1st gear and 2nd gear, but in 3rd gear, it spiked to 15psi causing it to bog...he had it set 12psi.....i dont know if it was just his bc or if its the greddy profec b-spec 2 itself...
error
