anybody ? try 93 nsx stock rims before on 240sx ?
POOPmouth
Car: The Devils pimp ride
has anybody tryed these or know by the size that fit a 240sx s13- also clear r32 brakes ?any info is good thanks
1991 - 1993 Front 15" 6.5" 15.20 lbs.1991 - 1993 Rear 16" 8" 18.86 lbs.
Lug Nut Torque Spec (all years) 110 N.m (80 lb-ft)Offset (1991 - 2001) 55 mm front, 60 mm rearOffset (2002+) 55 mm front, 56 mm rearCenter bore (all years) 70(.1) mm front, 64(.1) mm rearBolt pattern (all years) 5-bolt pattern, 114.3 mm bolt circleLug nuts (all years) 19 mm with 12 mm x 1.50 thread pitch
hannibal
Car: Red Line to Glenmont
NSX's use some very high offset wheels. The fronts are barely wider than stock and will sit further inside the fender. Clearance to the strut will be very very close. The rears have a better width, but that +60mm offset is rediculously high.
I'd pass on these...
POOPmouth
good info - i kinda thought it would be a problem --just wanted to ask around - thanks
whiterps13
Car: white LE hatch
Yeah those offsets wont work with massive spacers.
