Are we going to see 12"s?Darius wrote:I ran mine with stock fueling, stock turbo (@12psi) , and stock intercooler with lowered compression and head work at 14.4 @104 mph or something lame like that. I was also running all-season tires on my fatass S14.
A truly stock RB25 S1/S2 would probably do better especially with higher compression and if the rear transmission mount was solid or McKinney. I couldn't launch at all so it bogged off the line.
This year should be a little better though
ok sweet sweet, yeah stock is what 7 psi so thats pretty good, i was hoping to be between 13 and 14 so this is a good idea thanksmatafied wrote:i have put down 13.4 1/4 on stock motor with 10psi, also 2.2 60ft times so yea
yeah i have a light *** s13 and when the motor is going in im using mckinney so yeah i think it should be ok at least between 13 and 14Darius wrote:I ran mine with stock fueling, stock turbo (@12psi) , and stock intercooler with lowered compression and head work at 14.4 @104 mph or something lame like that. I was also running all-season tires on my fatass S14.
i was thinking about 4 psi for driving 6-7 psi for drifting and 12-14 psi for drag or telling 08 corvettes to shut uprb25drag wrote:Youtube or streetfire will be your best search engine for finding dyno times and track times. Every car seems to vary.
My car Mostly stock on 4psi, run 8.60's in the 1/8th mile.
haha no problem its all info to help everybody outDarius wrote:It will be better than on coilovers that's for sure. The rear should squat a lot better and the weight transfer should help plant more power. New toe links won't hurt either.
I've got cdorhout's old 265/40/18 falken's on the back so I'm not expecting anything great. I don't have money this year for drag radials and new wheels so I'll just have to go tractionless for the first couple gears It will be good for me to get used to the power.
Anyways, this is getting wayyy off topic. Sorry thrasherx89
I didn't realize you weren't buying tires this season. Good luck breaking into even the 12s with those ****ty tires. You're gonna have way more power than I did on them, and I couldn't even keep them planted until 3rd.Dig deep Darius, get some real tires.Darius wrote:I've got cdorhout's old 265/40/18 falken's on the back so I'm not expecting anything great. I don't have money this year for drag radials and new wheels so I'll just have to go tractionless for the first couple gears It will be good for me to get used to the power.
