Postby
redmanfx »
https://forums.nicoclub.com/redmanfx-u15036.htmlMon Sep 05, 2005 5:52 am
Other than the radiator and fan you can have a transmission cooler, Active suspension cooler and some may even have a cooler for the differential. That's alot of coolers!
Postby
FarFetched »
https://forums.nicoclub.com/farfetched-u25415.htmlMon Sep 05, 2005 8:54 am
Install it behind bumper on driver's side. If you could make it temp dependant, that would be awesome. Say at 170 it comes on and stays on to maintain transm fluid tem. good find!
Postby
redmanfx »
https://forums.nicoclub.com/redmanfx-u15036.htmlMon Sep 05, 2005 9:17 am
Hey, when you buy this cooler make sure He includes the brackets that hold it into place because if you want to put it where it would normally go on an active Q then you'll need those brackets. Ask about the air intake peice as well.
it would work well as a transmission cooler--but you really need the temp switch, relay, mounting brackets, etc. I'd guess it is 'equivalent' to the '10,000" towing' coolers that go in front of the radiator.
Unfortunately, the seller would not respond to my questions regarding the other misc. parts, so I decided to pass. Look for me in the wheel well of an old active Q in a salvage yard soon!
