Anybody running aftermarket 17" wheels on their Z?
Nissan 350z / Nissan 370z general community discussion forum
whipperace
Car: 2003 SER Spec V, 2003 350Z track, 1999 Frontier
I was just wondering if anyone out there is running aftermarket 17s on their Z. Got any pics? Size recommendations/offsets tire size? Or reasons to do it or not do it? I'm considering some aftermarket Enkei racing wheel and am just looking for some input.
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
Enkei makes some light wheels especially 17" and 18".
17" is good for performance, but not for look for Z.
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
The only reason I can see going with a 17" wheel is for performance. And the only thing you can squeeze out of that, that you can't on an 18" is most likely going to be weight. So you can get a lighter wheel with the 17" probably. I personally went for the 18" upgrade, lost about 3 lbs per wheel over the stock 17's. The reason I went for 18's is so in the future if I decide to go with a big brake kit I won't have to upgrade the rims.
Anthonysflying
Car: 2004 Silverstone 350z Touring
I lucked out and snagged a 17" set for $300 to get winter tires on. Turns out these 17s weigh 10 lbs each less than my stock 18s. Problem is the offset is out of control (+40 all around) I want to track the 17s though so i'm going to try the spacer route. Chances are i'll have some camber issues.
whipperace
Got any pics?
Return to “350z / 370z Discussion”
