anybody replace the power antenna?
Magnum PI
Car: (former owner of1994 Q45t)2005 Dodge Magnum R/T, 2008 350Z
My power antenna broke several years ago. The motor is good, just the nylon track broke. I bought a replacement mask with a new track from Crutchfield, but the remaining broken track inside the antenna prevents me from installing the new one per the instructions.
Anybody have experience with this? Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Quite a few post in the Infiniti Mechanic Forum (where this should be posted).
Must get the old tail out and hope the gears aren't worn too badly.
Magnum PI
oops, thanks for reminding me Maxnix, this forum thread is on my favorites, so I always wind up here. I found the thread, and it helps.
Aus94Q45
Car: 1994 Q45
I had to do this on my wife's Landcruiser. The tail broke inside the motor housing. I had to remove the unit and open up the housing. Not too difficult. I believe that you can get the unit out through the trunk. Pay close attention while taking it apart. I cleaned out the hardened grease and relubed it all with white lithium grease -- works great for the past two years.
