Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Mon Jan 24, 2005 3:34 am
I need some info from the FSM on the front strut removal. If anybody can help me, please do so.
It is a 1993 J30, with a little under 100,000 miles.
The strut boots are shot, but the struts seem to be fine. I want to remove the boots, but don't see a way to remove the struts from the front spindles. The normal bolts are not there. It appears the strut is pressed into the spindle. I am sure there is a trick to it, but I am not seeing it.
Thanks for the help!
