anybody remove the instrument panel recently?
gloucester Q
Car: 90 Q
i need to replace the bulbs behind the message window area in the instrument panel. was looking through the service manual--it looks straightforward--ish to remove the cover and panel, anything else i should be worried about? i don't actually need to remove the steering wheel or anything else do i? thanks. randy
DrewQ45
Car: 1990 Infiniti Q45
No, You don't remove the steering wheel, however, you will want to loosen the bolts for the steering column brackets to further lower the steering wheel.... that provides more clearance. I think you will also need to remove the ignition housing. (It's been a while)...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try a search. There is a good post on it.
See attached text file.
Modified by maxnix at 1:14 PM 6/29/2005
gloucester Q
Car: 90 Q
awesome write-up. kudos to the author. thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You dont have to remove the steeringwheel cladding but it might make it a little easier.. I hate taking apart the dash!
