I have been there 20 plus minutes of nothing but ls1s and 2jz.leesredgt wrote:I know its been done before,i just cant remeber who done it.Check out the hybrid section you might find your answeres quicker there.
zeroforum/201
iron block > aluminum blockHoosierSX wrote:motor mounts will be different from an ls1
ls1=all aluminumlt1=iron block, aluminum heads and intake
How do you figure? Not being a smartass but I really don't understand your thinking. I guess some of the newer Iron blocks will hold a s***load of HP.S13_love wrote:
Email sent.C3Sierra_S2000 wrote:If you are looking for a LS1 setup for a Nissan I am about to pull the LS1 / T56 combo out of my S14. I have something bigger going in I can set you up with a pretty good deal.
I always figured that iron blocks can hold a lot more power than aluminum blocks or they wont break as easy (however you like to see it as), old or new for that matter.fiznowler wrote:
The design of the block is the most important factor. If you look at the aftermarket blocks available for domestic v8s you'll find most of the super high performance blocks are aluminum. They just have more material in the right places.S13_love wrote:I always figured that iron blocks can hold a lot more power than aluminum blocks or they wont break as easy (however you like to see it as), old or new for that matter.
I didn't mean to hijack this guys thread but if ya wanna know. I am putting in an aluminum 6.2L L92 motor from an 07 Escalade that with a tune and cam makes 530hp at the flywheel. This thing makes 400ft/lbs of torque at 2000rpm I should have it on the road in about 2 months.s14derrick wrote:something bigger?
Yeah, thats true...i guess it really does all comes down to the design of the block in the end.Crazyirish wrote:
That sums up this discussion.leesredgt wrote:I know its been done before,i just cant remeber who done it.Check out the hybrid section you might find your answeres quicker there.
zeroforum/201
