anybody know these cars? i keep posting with no responses
MYFREE95,240SX
Car: 1995 NISSAN 240sx KA24DE 1995 NISSAN 240SX ka24de yes two of them
cars idle is screwed... in gear when warm only, will sputter and stall happens in reverse mostly when accelerating it sputters alot until about 3 grand then runs fine. car is a 95 ka24de with 207000 miles recently i have done.... injectors, wires, distributer cap, plugs, fuel filter, battery, 2 alternators due to a charging system issue that i think is fixed now. ummm.... thats about it. this sputtering issue is not new and was doing it before anything was replaced i cant find a vacuum leak and is now alot worse after doing injectors. when i disconnect mafs idle is really nice. please i need to diagnose this asap it is my daily driver and i need it to work. funds are low so start with inexpensive things. and im not some 20 guru so laymen terms help. i have the Chilton's for my car but they show a completely diff. engine then mine and i cant find half of the things they talk about. please help im here twice a day minimal with time to work on her.
cassa_bx
Car: 96 vq'd s14, 88 vw jetta coupe
possible bad egr vavle????
MYFREE95,240SX
are you guessing?
MaxType 240
Car: 1995 S14
Use fuel injection or carb cleaner, to clean: MAF, intake piping, throttle body.
What will end up saving the day is cleaning your IACV (very common problem, esp w/ high-mileage KAs): http://www.tamparacing.com/for....html
Jesse
MYFREE95,240SX
not the iacv did it this weekend getting a masf this week mines clean as a whistle. and im pretty sure its gonna be a sensor since it only starts happening after warm up when it starts looking for feedback so im doing masf, coolant temp ad both o2s over the next couple of weeks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
It sounds like your Mass Air Flow Sensor is failing under load when demand is increased. Check the inside of the MAF tube and look at the actual sensor wire for any debris, something like a fragment of a leaf will cause an altered reading.
MYFREE95,240SX
Clean as a whistle
shades14
Car: s13 n s14
I had the same problem. I just replace Da MAF sensor.. Runs stronger then befor!!!
