Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Sun Jul 03, 2011 6:03 am
Not sure about the tps voltage. He did have a Haynes manual in the truck and a bunch of tools in the back, so it seemed like he was a decent mechanic.
So, yeah... I went to look at the truck yesterday. I didn't buy it on the spot or even make him an offer... I told him I'd consider it and get back to him.
His ad says it has some rust on the cab corners... not really true.. they are completely gone. Just a big rusty mess. The rest of the truck isn't bad for rust.. one hole on a front fender and some bubbling and surface rust around the others.
He started the motor and it sounded good.. though it seemed like it had a high idle to me. After it got warmed up (45 second to a minute it seemed), it dropped revs a little bit (maybe 100 rpm at most), but still seemed to idle smooth. I didn't hear any tapping, knocking or anything.. seemed pretty smooth. I was expecting an erratic or choppy idle, but it was fine. So we decided to go for a quick "test drive". The trans shifts as smooth as butter.. The motor.. not so good.
If you let it run itself out on idle, it runs fine, but as soon as you touch the gas it quits and wants to die. I can't tell if its getting too much gas or not enough, but my guess is too much gas? When you let off the gas pedal, then it resumes running at idle.
So far my guesses (from other advisers or myself) for the repair would be the ignition coil, a fuel filter, or perhaps a vacuum leak.
Anybody have opinions on the issue?
Again, the rust was worse than I thought on the can corners and the clear-coat was peeling pretty bad, but I don't care that much about those things... I just want the utility of a truck.. for cheap.. so I know I'm not going to get anything pretty.
