anybody in richmond, va want to help with wiring
Vedoman
Car: 90 240sx s13sr20det
im about to do my first sr swap and i could use some help with wiring it up. if anyone has experince and wants to help let me know
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
The wiring is pretty easy. Get a soldering iron and some shrink wrap. Then, read the write-up on it. There's a link in the SR FAQ. I made the mistake of buying a used one when I first did my swap. It had a short. I said screw it after that and chopped my 2 harnesses to make the one I have now. It's not beautiful but my car starts now, and I actually learned a lot from it.
If you want something done right, do it yourself.
Justin35ll
Car: s13 coupe sr20det
I bought a used one for mine too, it was plug and play and I have no problems with it.
But I found the DIY after I bought it and it looks like it's pretty easy to do yourself as long as you know how to solder.I went over my whole harness to make sure the solders were good and it was done correctly
