mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Fri May 16, 2008 4:06 pm
you should have +12v to all injector plugs whenever the key is on. You get -12v on each injector as you spin the CAS, that's how the computer fires the injectors by grounding them out. Is that what you mean by 12v on both sides of each plug? Which brown plug are you referring to, take a pic?
