anybody help me? breaking axles
2jz
hi guys ... i have 200 sx i swapped the enjine from ca18 to a toyota 2jz but i faced some problem with clutch but solved this problem with an hks twin plate clutch. at the moment i face a big problem with the axle shaft always braking. What do i do????
Hijacker
Car: '92 240sx Convertible
'94 F-150
Moving this to 240 tech.
Welcome to NICO.
You're axle shafts are too thin probably and can't handle the power output of the supra motor.
480sx
Car: 1996 Pearl White 240sx
You mean to tell me you put a 2jz in a 200sx... Dude thats nuts lol. I didnt even know those things were rear wheel drive. What you need to do is replace your rear end with something beefier. You have to make sure you get the same length rear as the stock one and thats going to be your main issue. The main problem is is that no one mods 200sx's, your not going to be able to find much information on them. I would start looking for maybe a ford 9 inch rear or a rear out of some truck. Take a measurement of your rear end and find one that fits.
houdini
Car: 1993 Nissan 240SX Convertable
2001 Nissan Frontier CC
is the 200 a solid rear axle vehicle?
you might be able to find a suitable axle out of a hardbody truck (c200) or frontier (H233B) (9.25" ring gear. pretty much bomb proof).
