SeVa-S13 wrote:Is there an adjustment screw on the BOV? Where is it gettin vacuum from?
Yes there is an adjustment screw for the BOV and It's I put it all the way loose..and all the way tight with no noticable changes. I'm getting vacuum from a line that is leading to the intake manifold. I vacuum tested it and I'm receiving 15Hg of vac.
LEMHEAD16 wrote:7 psi with no fuel management? You are asking for disaster. Install your SAFC and WB 02 now. After you can see what is going on with things inside the combustion chamber then worry about how your wastegate is working.
Yes thats right.
I figured it's a pretty low psi and I'm pretty sure I'm getting a good amount of fuel, if anything I'm running rich. The Hi-Flow 255lh pump is pumping more fuel.
But then again, it only makes sense to intall the parts I already have huh? I was thinking maybe someone has ran into this problem or knew what it was. Next up I'm going to do the wideband.
Any other susgestions?
