sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Wed Mar 14, 2007 4:05 pm
It couldhelp some, but if it's the exhaust that's at fault, then you cannot do anything about it other than shield it. It is exposed to the outside as it is, under the car, so as you can see the air isn't cooling it down enough. You have to trap the heat and transfer it on back. Heat wrap it man, believe me, there are also power gains in that, additionally to the hot-leg avoidance.
An easier and more cost effective alternative to hood scoops is raising your hood by use of longer hood bolts and some large nuts (bigger in diameter than the bolts)
sil80
