Anybody experienced this before? P0301
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
I have a 2017 Infiniti VQ37VHR Q70sport AWD with a cylinder 1 misfire (P0301), here's what's been changed.
- spark plug
- injector
- coil pack
- entire injector sub harness
Misfire is still there, dealer won't warranty it, could it be the A/F sensor? I believe that would trip a P0300 code
cliffyk
Car: 2012 Infiniti M37 Premium Pkg
94Q45Beast wrote:
Sat May 18, 2019 10:18 am
- spark plug
- injector
- coil pack
Here is the P0301 diagnostic procedure from the FSM.
It is possible that the A/F sensor could cause the DTC--however that would likely affect more than one cylinder.
I don't see that cylinder compression or vacuum have been monitored, low compression, and/or a leaky or sticking valve, or VVEL malfunction could cause a single cylinder misfire. THe misfire detection monitors the crankshaft's angular velocity, I.e. The problem is not necessarily an ignition or fueling issue.
it could be a faulty or noisy (electrically "noisy") crankshaft position sensor--this was a relatively common problem with Ford's early EECV ("eek-5"; Electronic Engine Control version 5) system used on the '98 to '01-1/2 Mustangs, the ground shield in the co-axial lead to the sensor would break from vibration and cause the ECU to believe a misfar had occurred, when it actually hadn't...
94Q45Beast
1992 INFINITI Q45
It's been sourced down to wires being shorted somewhere, car won't even turn on anymore or display any lights, had a list of CAN communication codes that dealer ignored with a idle relearn
