AcMav »
https://forums.nicoclub.com/acmav-u86256.html
Tue May 06, 2008 4:55 am
I've seen it tried and failed miserably on Mythbusters, ending with the Engine catching on fire. I wouldn't say this is something that'd go in easily and run better out of the box.
If you have enough time to spend tinkering I think it may work, the ideas are sound behind it, But I wouldn't want to risk ruining my engine. Our engines are designed to run off Gasoline, a liquid, not Hydrogen Gas. The fuel systems not designed for transporting this gas, nor is the engine designed to contain it.
If you're up for it I'd love to see someone try it with pictures, Coming from a chemical engineering field I'm not comfortable with a "hydrogen bomb" as they state it under my hood. You stall the engine then try refiring and I wouldn't feel too safe.
Modified by AcMav at 11:08 AM 5/6/2008
