elwesso wrote:Take your car to a local shop that does performance stuff and theyll roll your fenders for like $30
No offence, but why pay someone to do something so easy?
Here's what you need:
Hammer, small propane torch, a shop rag and patience.
Step 1: Simply take your wheel off, heat up your fender lip with the propane torch (make sure it's a low flame, and you keep it moving over the area you are going to be rolling) Using a torch is not necessary, however, it will help prevent paint chipping/cracking during the process. (On that note I was able to stretch my s14 fenders out about 10mm WithOut cracking the paint at all by using this method, and a eastwood fender roller) *Also, remember you have a plastic fender liner on the rear aswell as the front, I would suggest removing it, however, if you want to keep it on just be aware it's there when using the torch.
Step 2: Take a shop rag and place it over the end of the hammer you will use to hit the fender lip with, this will also help prevent paint chipping.
Step 3: Begin to tap the fender lip upwards, I've found that Q45's have some pretty stout metal here (in the rear), and it may take a little force (here's where the patience comes in) but, take your time and go slow it will roll just fine. If your doing the front fenders, it'll be a breeze, the metal is very pliable.
After a couple min, reheat the fender, as the metal will move easier when it hot, and the paint will have much much less tendancy to crack.
That being said, I know there are a lot of scarry words in this post like hammer and torch, however, I've done this many times and on 2 different Q's (a G50 and a Y33) and both turned out great. Don't let those scarry words throw you, it's very easy and can turn out great if you take your time (can't stress take your time enough..lol)
I have an eastwood fender roller, and I prefer this method simply becuase I've found it's faster and easier.
I wouldn't suggest using a bat, but if you do please heat your fenders before doing so.
<NOTE: Added some bold for emphasis.>
