Thanks for the best wishes but i won't be able to autocross (well it would be dumb to try) because i need to fix this problem.mr2lickit wrote:hey welcome to the world of a 240 haha. Yeah it sounds like your ps pump is going. Also make sure you use red power steering fluid (don't ask why cuz I don't know haha). I just know when I did it all the resistance and noise went away. Oh and GL on the autocross!
That's what some people, including Exarkun told me i should try. I'm just a little confused about it when Nissan itself doesn't do or recommend power steering flushes as part of any regular maintenance program. I already have the pump sitting here. Its a remanufactured pump w/ a lifetime warranty.skylndrftr wrote:sounds lke something might be plugged... the whirring noise could be the pump trying to pull fluid. before you spend a hunk of change on a pump i would suggest trying to see if you can find someone to flush the system. Never heard of a PS flush though might wanna see if a trann yflush place will do it. Theres a lot of little valves and orifices to plug up
I guess I only have a matter of time before my pump goes. So were the symptoms the same? I.E., stiff and reluctant to turn to center?ricebike wrote:sky, sorry for late reply...
here's a simple way to DIY w/ a helper...
click me!
I was about to do that, but my pump died on me w/out warning!... napa's overly expensive lifetime warranty pump saved the day (this was b4 I was on teh internetz)
Well my wheel stays 'centered' it just won't return to center if i make a right or left turn where i turn the wheel, say 20 degrees or so. I haven't done anything as of yet but I'll post back when i find the problem.spocky wrote:any news? I'm suffering from a similar problem (whirring, wheel not staying on center), so I'm curious how it's coming.
The power steering fluid used in the 240sx is the same as Automatic Transmission Fluid(ATF). Nissan used it because it tends to have a higher boiling point and the fact that it is thicker than standard power steering fluid.mr2lickit wrote:hey welcome to the world of a 240 haha. Yeah it sounds like your ps pump is going. Also make sure you use red power steering fluid (don't ask why cuz I don't know haha). I just know when I did it all the resistance and noise went away. Oh and GL on the autocross!
Thanks for your post. Well being that practically everything up front is new: new kyb strut mounts, agx's, new control arms, tein inner/outer rods, spl t/c rods I can't imagine anything else I should be considering. My S.A.I. is off on the right but barely enough to cause an issue. I can't imagine my 16lb wheels and 225/50 tires being the reason why the steering is so stiff and unresponsive.skylndrftr wrote:reading this it sonuds more and more like something besides to PS. the self centering is caused by suspension geometry not power steering.
deffinatly what I was thinking, The only way I can think for the steering system to be messing up is perhaps the valve in the steering rack that directs the pressure to one side of the rack or the other is bleeding pressure. reguardless though that would only equalize pressure on both sides and that really shouldn't keep it from centering...skylndrftr wrote:reading this it sonuds more and more like something besides to PS. the self centering is caused by suspension geometry not power steering.
