anybody done a oil pan upgrade on ka-et
214kka-et240sx
Car: nissan s13 silvia
need to upgrade my to a bigger oil pan on a ka-et but don't dont know who makes it or what i can do i was thinking of a sr greedy pan i think its not sure but taking it and weld it on to my pan or any one know who makes them reason is when i go out drifting for like 5 min my engine get retarted and the valves start tickin cause of oil pump not getting enought oil so help out a nissan onwer thank u
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
How about modifying the windage trays in your oil pan,
240SicknessX
Car: 96 240 SE
umm, do you have enough oil in there? are you running the correct weight? i never have a problem with my 96. add 1\4 quart. see if it helps.
the trays in the oil pan i belive are supppost to keep the oil from sloshing all to one side and running the pump dry for a few seconds...... i dont know if you want to edit them in any way.
i havnt personally looked at the oil pump on my car, could the pick up be clogged or loose?
do other single cam owners have this problem?
214kka-et240sx
no body that i know of that has a ka-t single cam going drifting and having the same problem than me
i will add more see if it helps thanks
wild_maxx
Car: 90 TT pearl yellow z32
cant you just use the DOHC oil pan. it has better baffles in it.
214kka-et240sx
dont know if it will fit
D Money
Car: driving illegaly
i think it should. And i think i have one! make offer [email protected]
