NOR*CAL 916 wrote:haha i get high beamed quite often, i have generic ebay hid's. there 6000k and are freakin awesome, i love them.
The refectors in your lamp assembly are what dictates the beam shape and pattern. More light doesn't change that. Q45s have a sharp cutoff at the top of the beam to keep from blinding oncoming traffic. If you're getting high-beamed, it's not because your lights are so bright, it's because they're aimed too high, and maybe too far to the left. They have a beam cutoff on the left too. If you blind someone and get head-on'ed, you won't say "ha-ha".
Note that if your lights are blinding oncoming traffic because they're aimed too far to the left on low beams, they're not aimed directly ahead on high beams, but too far to the left, not good for any fast driving.
That being said, I like my lights aimed correctly but a little higher than factory setting, but not so high they blind other drivers. As I mentioned, I set mine so that the top cutoff is just slightly above the top of the trunklid of a car about 25' in front of me. Not enough to hit his rear-view mirror and blind him from behind, but enough to be able to clearly see the top of his trunklid.
I strongly urge you to re-aim your headlights. If they are aimed too high, they may also not be aimed straight ahead where they're supposed to be.
Find a level dark place where you can SEE the headlight beams on a plain flat light colored wall and get the car perfectly straight to it. Look at your beam pattern, and adjust the lights so on low beam, they are even and the left cutoff is about where the centerline on the road would be, and the top cutoff is about even with the top of the headlights. You will see a lot more light on the right side of the pattern, and that's the way they're supposed to be, so you can see the right side of the road and signs well. Then when you drive in traffic, watch where the top of your beam pattern hits cars you are behind. You can fine-tune the height adjustment so the top cutoff just shows above the trunklid of a car you are about 25' behind.Make sure the beam is not blinding that driver in his rear view mirror.
With the brightness you have from your bulbs, that will give you very good lighting when driving, and will be safe, for other drivers, and for yourself.
