any1 in tucson az wanna help ill pay.
ygostr8
another ? i know its getting old but need help please, thank uanyway i got the car runing, turns on idles, stays on but when u try and give it gas it starts trying to shut off and runs like crap, after about 2 min of trying to drive it it shuts off automatically, i check the ecu and get code 55,i cleaned my maf, and checked for leak nothing helps i got a s13 with an rb20det stock with only exhaust intake,fmic,and a sx performance frp.btw does anyone know how much psi i should set frp at im runing stock boost, i think its a fuel problem cause my frp is set for a turbo ka with 50 lbs injectors chiped ecu different fuel rail and maf, and my rb20 is pretty much stock so can someone please help me, thanks in advance.
Joe
boost leak
and what does your old KAT setup have to do with a rb20? none of that stuff is reused.
ygostr8
the frp im using is set for a ka-t, so im guessing its letting in to much fuel and causing my engine to die.
Kamin wrote:boost leak
Joe
i doubt it. check for boost leaks. also your MAF wiring and the sensor itself.
wild1100
i had a buddy with a sr20 had the same problem went over to his house and he had the return line and fuel line backwards
