Any word on a replacement for those Eiback Pro-kit Springs (Q45, 90-96)
blacklist74
Car: 1994 Infiniti Q45
Any word on a replacement for those Eibach Pro-kit Springs (Q45, 90-96). Cali customs are very nice, but I live and drive in NYC. I can't have such a low drop. I need something just like those Eibach with (1.0" front and 0.8" rear) drop. Too much pot holes and speed bumps all over the damn place.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, read very carefully first to understand how it changes the suspension and what must be donw to compensate. It's all in the mandatory reading of Q45tech's posts.
If you don't find a set (and there are probably a few on the shelf out there) it will have to be a custom solution.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I had the eibachs on my Q and I dont notice any difference as far as the car sitting lower... the rear is about the same, the front just has a tiny bit less fender gap...
I dont think its gonna give you any issues. The eibach springs are gone for good...
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
I've searched the Infiniti online Mechanic forum for the following:
SpringsLowering springsEibachCal Custom
All searches returned zero results. This wonderful search is at the least - frustrating.
96Qowner
Car: 1996 Q45
You have to select Post Bodies, or you're restricted to only those threads with your search terms in the title. I found 6 threads for "springs".
Rex
Car: None
Not that I know of, seems someone was talking about having some custom made, but I haven't heard any more on that topic.
66mgb wrote:I've searched the Infiniti online Mechanic forum for the following:
Used the same words (dropped the "s"), and used the in body of posts option and got several results. I also searched both Infiniti Online Mechanic and the Infiniti Q45 sub-forums ... as seperate searches.
Jesda has a good tips/tutorial post somewhere ... took 2 triesd as it was archived .
litlchi
Rex wrote:Not that I know of, seems someone was talking about having some custom made, but I haven't heard any more on that topic.
The person he is referring to is: tarmacsuspension
From what I remember though, he was going to make a copy of the Cali Custom springs, but I might be wrong. The thread is zerothread?id=172108but I think page 3 is the only part that is semi-relavent. It might be worth sending him a msg.
superuber
elwesso wrote:I had the eibachs on my Q and I dont notice any difference as far as the car sitting lower... the rear is about the same, the front just has a tiny bit less fender gap...
So, the cali springs are lower than the eibachs?I thought the eibachs were a 1.5" drop?What are the cali's?
blacklist74
There has to be someone or company that still have these Eibach or something close to them. Someone on NICO might have ran across them or know of someone that has them... Need some info..
