Any way to "tap" into the AUX
All things Altima Coupe.
3.5PandaCoupe
Car: 2012 Nissan Altima Coupe 3.5
I have a SAT tuner in the car and have it running to the AUX outlet on the radio. I don't like seeing the wiring and want to know if there is a way to tap into the back of radio and hardware the AUX cable. Anyone know if this is possible?
Before it's even mentioned ... I know I can set the SAT tuner to a radio station and that will eliminate the wires but I don't want to go that route.
If someone can help with the AUX hardwire, if it's possible, I'd really appreciate it.
Thanks!
centralcoaster33
Car: 1997 Nissan 240SX #5
You could take apart the head unit to access the back side of the Auxiliary input socket and solder another set of wires and another socket on there that is exposed on the back side or wherever you put it. You'd need a sort of permanent mount location for your Satellite radio tuner and then a route for the wire from that to your new Auxiliary input.
