Any using the ATI super dampner?
s13rb28
Car: 1990 nissan 240sx hatch
I was just wondering if any one is using this dampner and if so what did you order? I was gonna order the r32 600-1000hp but then there's the r33&r34 600-1000hp i've got an rb25 but i'm running the tomie 2.8L stroker kit.
StricNyne
i was looking at the ross pulley talk to compulsive hp jim about it we oculd buy at same time
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
I had one built with just one pulley on the inside and a drysump drive were the other two use to be. The shop thats doing all my lower end work miked out the crank and they had to make it one off. ATI has a custom order dampner app. on there web page. Its not cheap but I didn't have the room to use there stock order dampner + the oil pump drive. Just call them and describe what you have done to your engine they will be able to make or mach up something to work. Best bet is to just call them. But if you need a custom one you just have to fill out those papers on their web page and send them in.
