Any using a GodSpeed front mount?
goalguy02
Car: '92 240
Is anyone using a GodSpeed FMIC and if so can you take some pics of the hot side piping? I ordered mine, which came with no directions and I don't have the stock intercooler. I want to see how the hot side fits. Does it go through the small intake hole under stock airbox and how much of the factory intercooler piping do I need to make it work? Thanks.
240 GTR
Car: '98 Nissan 240SX
2006 Yamaha Raptor 700R
i didnt use any of the stock ic piping. i just went to Napa and bought a piece of radiator hose with a 45 degree bend in it and some hose clamps to connect the 2 pipes
goalguy02
Car: '92 240
Thats perfect! Thanks alot!
goalguy02
Car: '92 240
One more question, My piping didn't have a wastegate nipple on the hot side. Where did you run your wastegate nipple? I figured tapping a brass nipple into the hotside pipe wont be hard but want to make sure. Thanks again!
krazys13
Car: S13 hatch
I have been conteplating buying the Godspeed FMIC. I tried searching for opinions on it, but didnt have any luck.
Is there a lot of people running this setup? Seems like a good deal. I'd just like to hear some user opinions on the quakity and fitment.
goalguy02, let me know how it turns out for you.
Modified by krazys13 at 8:57 AM 2/6/2008
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i have an ebay fmic and its very nice. on the evo forums they did a test and they held up to 450 whp.
CMG
Car: 1989 240sx Hatch w/ Redtop
Aren't those generic FMIC kits around $250 to $300 shipped? You can get a Greddy FMIC spec M or LS for around $400.
david200095367
nope i got mine for 195 shipped.
240 GTR
my hotpipe didnt have a nipple on it either. i just ran the wastegate line to one of the open nipple on the throttle body.(i know its not right or good for response, but its all i can do.)
one thing i dont like about the kit is that the piping is VERY thin. i'm sure its fine, but i would've liked to see something that looked a little sturdier. i installed it this past june, and i havn't had any problems with it.
Tulsa_S-13
Car: 1991 SR 240sx
CMG wrote:Aren't those generic FMIC kits around $250 to $300 shipped? You can get a Greddy FMIC spec M or LS for around $400.
Yep. Going through ProjectSilvia and ebay I put together my FMIC for approximately $350. The internal design is literally bar and plate!
After seeing Redtop's GReddy M-spec FMIC in person, the M-Spec has a much better internal design allowing for less backpressure (better response) and has fairly beefy pipes.
Wish I would have spent the extra money for the M-spec.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Ryon has a Greddy VSPL. I have an M-spec (no internal pics) but will tell you that mine looks like it will flow much better than the one you have.
Tulsa_S-13
Car: 1991 SR 240sx
Nope, Ryon has a GReddy M-spec. Trust me, I've seen it in person and have talked to him about it when he was deciding between the M-spec and piecing together a eBay hybrid.
homeslicej2
^ zerothread?id=308744Read the fourth post down. He got the VSPL bc he new that his HP goals would exceed the M-spec and bc of good price. I've seen inside pics of his and it's the tube/fin design, whereas my M-spec is bar/plate.
Modified by homeslicej2 at 11:10 AM 2/7/2008
Tulsa_S-13
Car: 1991 SR 240sx
Damn, then I'm not too impressed with the VSPL then. I would have thought it'd have denser fins.
Homeslicej2, do you happen to have internal pics of the M-spec? I'm curious as to how it compares to my (more than likely) chinese unit.
homeslicej2
I don't I forgot to take some when I had the front end off and haven't hassled with it since. I'll get some this weekend though for you. I had tried to find a thread from awhile back where a guy had asked for pics and Ryon had posted inside shots of the VSPL, I forgot to get that guy pics . I'll do it this weekend though (won't be home before dark tonight and tomorrow), shouldn't take long. I'll just undo the coupling at the lower hot pipe/endtank and snap a pic.
Tulsa_S-13
Car: 1991 SR 240sx
Awesome! That'd be great.
I still want to ditch my FMIC in favor of a V-mount setup, but the money tree doesn't seem to be blooming anytime soon.
homeslicej2
Tulsa_S-13 wrote: but the money tree doesn't seem to be blooming anytime soon.
Too true
BoBa524
Car: 1995 Nissan 240SX SE
i will be buying a front mount soon for my s14 and was thinking bout the godspeed one also. but i would like to know how much better is the m-spec. i wan something that will have vac/boost ports in places where they are supposed to be.
sorry not trying to thread jack but this forum has been providing good info so far bout front mounts.
krazys13
Car: S13 hatch
I would love to hear some more opinions on the Godspeed FMIC. Seems like some people are using them with no complaints. Anybody??
leroiboy
Car: 1989 Nissan 240SX Coupe
i got the godspeed fmic kit from ebay $150 shipped. although i habe not had my car for very long, it has given no problems. my only issues were i actually ended up getting an s14 kit for my s13 sr. and then still, making it fit was no biggie(i kept it because ill be swapping out with a buddy that did the same as i did with his s14 sr)
goalguy02
Car: '92 240
I haven't had any issues other than not getting directions with my kit. The piping is REALLY thin, some kind of pot metal. I bought the intercooler kit with a turbo xs RFL bov for 220 shipped. Had to have the bov flange welded onto the hotpipe and because it was thin pot metal, nobody wanted to do it. Also had a small pit hole in the hod sie elbow pipe. Fixing that and welding the flange cost me an extra $60.
Is it ok to tee the wastegate off the same line as BOV? I read that the BOV should have a deicated vacuum source, but have seen many cars with tee'd lines at the bov.
krazys13
Car: S13 hatch
I've T'd off the bov line before without any issues...
Well it seems like they're good kits minus the thin piping. I guess one can't complain much for the price. Anybody got any good pics of the core??
Sorry for the hijack.......
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i just got my greddy ls intercooler. cant remember if it is the bar and plate or tube desing. but it is huge and will meet my needs no problem
goalguy02
Car: '92 240
krazys13 wrote:I've T'd off the bov line before without any issues...
I can take some pictures of this one later today or tonight. Thanks for the input on wastegate vacuum!
homeslicej2
idahotuner wrote:i just got my greddy ls intercooler. cant remember if it is the bar and plate or tube desing. but it is huge and will meet my needs no problem
The LS is a tube and fin design. Tulsa, I took some pics of my core, but forgot to bring my camera with me today , I'll get them on tomorrow.
captainfalco
Car: S14,MX83
I just got my Greddy ls from vividracing (site sponsor) for like 379 plus shipping. Very nice quality, better than my old ebay one.
krazys13
Car: S13 hatch
goalguy02 wrote:I can take some pictures of this one later today or tonight. Thanks for the input on wastegate vacuum!
No problem. Yes, please do get some pics when you get a spare chance.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I got mine free because fatboygaradge messed up my order than wouldent refund me! I disputed it with paypal and got my $300 back and kept the fmic kit! All because they sent me a black fmic instead of pollished! I love the black fmic its soo stelth some pro drifters cant tell my car is turbo @ 10 psi !Fatboy sends crappy piping, I dont think GS makes brushed piping with 90% sharp bends! every time boost creeps to 12 psi PISSSSSS piping pops off!
homeslicej2
I keep forgetting to bring my camera to work to upload pics Suffice to say that I will again try to remember, but that my M-spec core actually looks very similar to yours.
CMG
First you say how cool it was that you ripped off that seller by keeping both the fmic and $, then you say how much you like the one they sent you anyway...isn't that a little a**hole-ish?
