texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sun Mar 01, 2009 11:51 am
I recently took my Qship to a 'high speed Driver Education' day hosted by the Austin Porsche Club--the 2nd time for me. The new track was by Sam Marco Airport and the layout paid great premiums for maintaining momentum through curves and getting the line right on the money. For this run, I installed Porterfield 'racing' pads kevlar and carbon, front and rear, have Goodridge sstl lines, stock rotors. Also got a set of 16" wheels from 95 Q45 and mounted new set of Kuhmo 245x50 ultra high performance summer tires. Carefully followed Perterfields detailed installation and break-in instructions.
At the track, I could brake with all the Porsches-making up distance actually, corner with the best of them, and out acelerate all but the 'turbo's' . During each 15 min heat, I actually would pull into the 'hot pit' and let the field get at least half a lap ahead and then go again catching them in another 4 laps or less.
I was cooling system limited though, running one heat holding transmission to 2nd max except on longest straight, keeping engine between 5-7000 RPM. Was faster around the track, but heated up last 2 laps so had to back off. Ambient was 65F. Gonna install bigger transmission cooler and thicker radiator core.
Brakes were FANTASTIC--could bring tires to ABS point anytime, and never ran out of traction, even drifting throught the down-hill off camber, decreasing 'turn of death' that saw numerous Porsches in the grass that day.
I really do not see any need for larger rotors or calipers on a Q45. Several Porsches lost their brakes that day, I had solid pedal all the time, and I am a neophyte track driver.
The Porterfields are fantastic even in street service, not noisy or too dusty, easy on rotors too--their 'burnishing spray' coating works wonders.
Everyone kept asking 'what have you done to the car to make it so fast and corner so well.' Nobody believed it was a strictly stock 94 Q45a, with just a front strut tower brace. My instructor could not get over how flat the car cornered andhow it did not dive on hard braking. Active Suspension works.
